Sponsored by: Kumho
expedition front brake vibration
Old Mar 23, 2004 | 08:22 PM
lobstershift's Avatar
lobstershift
I have a 1999 expedition /w 70,000 miles. When the brakes are applied the front end vibrates. I've change the pads and turned the rotors three times. Problem comes back after about 8,000 miles. I'm using cermic pads. Any Ideas? Thanks
Old Mar 25, 2004 | 04:56 PM
turbo TED's Avatar
turbo TED
Lightbulb
lobstershift; Have the rear ones been done? And when the front ones are done do you not feel the shimmy anymore or does it just reduce it? Has anyone looked at the upper ball joint's & lowers also the tie rods. You may not have any problems with the chassis but you never know, FORD chassis are
virtualy bulletproof. turbo ted
Old Mar 25, 2004 | 11:38 PM
lobstershift
Thanks turbo ted. The rear have been done once. The vibration completely stops after a brake job. If I spin the front wheels I can hear the pads making contact with the rotor then no contact then contact again. I think the rotors keep geting warped but I don't know why. lobstershift
Old Mar 26, 2004 | 08:47 AM
turbo TED's Avatar
turbo TED
lobstershift; You may star with just replacing the rotors & pads again, A couple of things that could be causing the warpage is someone just torquing down the lug nuts with an impact & not using a torquestick also at this time if they do not use a star pattern on the lug tightening sequence these both may cause premature warpage, driving alot in a rainy climate as the rotor is constantly drentched or splashed by water it just tempers the rotors, if you have a hanging caliper [binding caliper] this could be causing the warpage also. I hope for your sake that you have a 4X2& not a 4X4 the 4X4 rotors can
be a nightmare that only gets worse as the day goes. Advance seems to have the best prices & warranty on the rotors. TURBO TED
Old Mar 29, 2004 | 11:35 PM
lobstershift
Turbo Ted, Thanks again for the advise. I tighten the lugs in a star pattern with a lug wrench, I'll use a torque wench when I replace to rotors and pads. I live in southern CA, not much rain. I have a 4X2. I rebuilt one of the calipers on the second brake job I did. They seem to be moving freely. lobstershift
Gevans17
Sep 14, 2013 10:48 AM
wogdiml
Jul 6, 2012 04:53 PM
mcassel1
2004 - 2008 F150
Aug 23, 2010 02:25 PM
Greg230
Jul 19, 2006 01:59 PM
buckarooboy
May 28, 2006 04:09 PM
