Any other blown head gasket signs? Water in the oil, etc.? Probably got some bad valves, did you put a teaspoon of oil in the bad cylinders and re-check them to see if it was bad rings? Let me look back because I did the same thing on my 360 about a month ago and posted them here.
Here is what mine had:
1-125
2-120
3-100 (112 with oil)
4-125
5-120
6-125
7-124
8-75 (85 with oil)
Something is off... maybe my gauge is done, gonna try another. Has anyone else seen consistent low numbers in a 360fe? I am guessing it has roughly 130k on it. Have no idea of maintenance history, but it is original to truck. re-ring time and some heads to the shop?
