Sponsored by: Innova
Mounting question.
Old Mar 23, 2004 | 02:31 PM
Dawg021's Avatar
Dawg021
Mounting question.
I found a realy good deal on a set of Infinity 6000cs 6.5" Component speakers.
I drive a 98 F150 ex cab 3 door.
Crutch field says 5.25 inch components are recomended.
if a 6X8 is whats in there from the factory im just wondering if i can make these fit or am i better off looking for a set of 5.25?
Old Mar 23, 2004 | 06:43 PM
nogo73's Avatar
nogo73
you could put an 8" speaker in your door if you wanted to I think the 6.5 will work if you don't mind modiflying the speaker holes to make them fit.(sawzall required)
Old Mar 23, 2004 | 07:49 PM
brianas's Avatar
brianas
there may be an adapter plate available for what your trying to do check www.partsexpress.com
if not - I usually make adapter plates out of 1/4" hard board and
coat with a piece of sound deadner
its actually pretty easy if you take your time
g/l
Old Mar 23, 2004 | 09:43 PM
bill6302's Avatar
bill6302
6.5's will fit in a 6x8 opening. i have a set in my 6x8 openings and didn't have to modify anything. or just take a grinder or sawzall and make them fit.
bill
