1978 - 1996 Big Bronco
whats wrong with my bronco?
Old Mar 23, 2004 | 05:03 AM
muscletruck7379's Avatar
muscletruck7379
Angry whats wrong with my bronco?
last thursday when i was coming home from school i came around a corner and my bronco just died. still had gas, and would still crank, but wouldn't even fire,(and it had a burning smell) so after getting someone to come after me (which they didn't, my dad couldn't understand that i was on road 6, not 9 which i got in trouble for) but after sticking my ice scraper between the seat and the clutch i was able to turn it over from under the hood. no spark. so on a lucky chance i took the 10 ga wire that was to my fan, stripped off the end, jammed it into the side of the coil. and on luck it fired up and i went like a honda-bein-chased-by-a-mustang home. to which it died again coming in the drive way because it blew the fans fuse. i tore apart the dash to ispect wiring and was able to find nothing, no wires were burned. but yesterday i tried it, and it fired up like nothing ever happened! which is bad because i haven't messed with any thing yet. i think that its the ignition switch, but dont know how or even if i can test it at home. has anyone else had this problem?
Old Mar 24, 2004 | 03:30 AM
bigric's Avatar
bigric
You could have a flaky pickup coil; if it doesn't sense distributor rotation, then the coil doesn't get power. The pickup coil is mounted in the distributor. I think you can check it with a meter; it's been a while since I've had to mess with one. Or you could have a bad ignition switch.
Old Mar 28, 2004 | 07:02 AM
nechun's Avatar
nechun
One common problem that I haveseen is the EEC relay. if your bronc doesn't have it, also check the fusible links at the ignition coil. you could have one ready to go
Old Mar 28, 2004 | 07:30 AM
bronco5.8's Avatar
bronco5.8
Muscle truck,
Also check your ignition module.
Warr
Old Mar 29, 2004 | 09:11 AM
muscletruck7379
it turned out being a bare spot on the tachs power wire, grounding out on the steel fuel line. i had it aperat for a week looking for that little thing. i kinda felt stupid when a friend pointed it out
Old Mar 29, 2004 | 11:26 AM
bsmith's Avatar
bsmith
That's what friends are for. Isn't it a great feeling when you finaly find something like that though?
Old Mar 29, 2004 | 06:05 PM
bronco351's Avatar
bronco351
Congrats on getting your truck fixed. Sometimes these Broncos can be a pain. I sill love them though!!!
