here I go again
Old Mar 23, 2004 | 12:34 AM
X-1's Avatar
X-1
here I go again
Decided to double check my timing after installing the cam, did the whole static timing thing, top dead center, then set the timing mark, and pulled the distributor. Problem is now I can't the disributor back in!! I think the shaft to the oil pump is not in all the way, I played around with it for a couple of hours, and for what ever reason it won't go back in. Any ideas other than pulling the pan and resetting it thru the bottom? Man, I should have left well enough alone.
Old Mar 24, 2004 | 05:13 PM
RTM's Avatar
RTM
When I have this problem I just bump the key a few times with the dizzy in place. What this does is turns the motor over and in turn in turns the dizzy which then rotates enough to line up with the oil pump shaft. You can also use a 15/16 socket on the bottom bolt and turn the motor by hand to get the dizzy to drop in the rest of the way.
You shouldn't have to pull the oil pan unless something is really wrong which I dopt there is. Try the above first.
Old Mar 24, 2004 | 05:52 PM
daerhldgs2's Avatar
daerhldgs2
If your timing is right once you have the dist. in far enough to engage the cam shaft gear than it is safe to bump the starter or manually turn the motor with a 15/16 socket on the crank bolt, this some times works best because you can turn the motor with one hand and press down on the top of the dist with the other , the problem you are having is because the hex shaft is out of sinc with the end of the dist shaft and a slight turn will engage it.
Old Mar 24, 2004 | 08:53 PM
Slade901's Avatar
Slade901
I did have encounter that same problem trying to put back the distributor back in.
On our 1982 Ford E150 5.8L 351W engine, the rotor rotates counter-clockwise. Anyway, I've noticed and documented that when the rotor was pointing on the spark plug terminal #1 and I remove the distributor the rotor is pointing close to the next firing order about 20 degrees.
I tried pushing it down and it won't go down and later on I realized that the distributor has to turn to go down to engage the teeth on the camshaft gears and the distributor gears. So for my engine type, I have to put the distributor 20 degrees ahead of the spark plug terminal #1 and the distributor has to turn clockwise while pushing it down to get it engaged properly.
Old Mar 24, 2004 | 10:30 PM
X-1's Avatar
X-1
Thanks guys,
I did get it to drop today, but I had to lightly tap the distributor in, I drove it a little, and everything seems okay, I am hoping it dropped into the pump right, I guess with the distributor in it would have to be.
Old Mar 25, 2004 | 04:33 AM
RTM's Avatar
RTM
If it wasn't your motor would know by now, no oil pressure,
shorerider16
Jun 11, 2013 12:23 AM
Banshee426
45
Jun 4, 2010 12:53 PM
ksmith203
Apr 30, 2007 09:58 PM
71SPORTCUSTOM
Jan 5, 2000 12:14 AM
