93 Explorer Turn Signal Problem
Old Mar 22, 2004 | 10:35 PM
nootch's Avatar
nootch
I have a 93 Explorer and the turn signals will not flash. So far have checked all the bulbs and the flasher. Also installed a known good multi function switch and still no flashing. The emergengy flashers work and the turn signals flash when activated manually. Don't have a circuit diagram but suspect there must be a wiring problem somewhere. Any ideas would be greatly appreciated
Old Mar 23, 2004 | 10:24 AM
mrshorty's Avatar
mrshorty
I would suggest getting that wiring diagram. They're not that hard to come by. Try the library for repair manuals or check out the repair guides at www.autozone.com
