clucth linkage
Old Mar 22, 2004 | 08:59 PM
redneckmechnic's Avatar
redneckmechnic
clucth linkage
Hi i converetd my truck form a c6 to a zf 5 speed about a yerar ago. the other day i noticed the clutch is starting to engeag way down on the peddale travle. closer look showed that the linkage going form the master cylinder to the peddal assambly was very well worn. these are all new parts a year ago. i was wonder should there be a brass bushing in that linkage. i never had on and i noticed the hole in the linkage seemed big but did not think anything of it.
Old Mar 24, 2004 | 01:55 PM
redneckmechnic
doesnt anybody no or is my question to vague?
Old Mar 24, 2004 | 07:07 PM
dpuff's Avatar
dpuff
I had the same problem with my factory installed stick shift. That linkage is notorious for bending and the ball joint breaking. My shiffter started doing the same as yours until the unit bent so much that the ingnition interlock with the clutch no longer worked. The the ball joint broke and the pedal went to the floor. The ford dealership repaired it at a cost of $700. My new clutch master cylinder had to be replaced again at a parts cost of $140. I was not a happy camper. I got 50,000 miles on my linkage. I'm wondering when it will bow and break again.
I didn't get under the dash and do the work so I don't know about a brass bushing.
Old Mar 24, 2004 | 09:18 PM
ditch witch's Avatar
ditch witch
RNM,
If you're referring to the "eye" on the shaft protruding out of the master cyl. towards the clutch pedal, yes there should be a bushing there. I think some were brass, some a plastic. Also, the early setup did not have an adjustable extension on the master cyl. You can change that to one that is adjustable and has a lock nut to hold it in place. The bushing is available from auto supply stores at about $4.
Old Mar 25, 2004 | 09:38 AM
redneckmechnic
okay thanks iam heading over to ford later today to get some parts ill see if they have that bushing. looked at yesterday and the darn linkage is wearing the pin thats welded to the peddal saaembly. its about half wore down guess ill have to remove the pedals and weld it up. oh well should be fun. Thanks guys
Old Mar 26, 2004 | 07:25 PM
whaleyddd's Avatar
whaleyddd
The clutch linkage has two bushing kits.
E69Z-7526-A for the eye bolt into the master cylinder.
EOTZ-2471-A this kit has 4 bushings in it and are on the main clutch saft that is shared with the brake pedal.
Feels like a new truck.
coreyallan01
Nov 22, 2015 01:17 AM
zackinno70
Nov 17, 2015 01:44 PM
97vanswap
Jul 3, 2015 10:47 PM
taxgod4u
Feb 24, 2013 04:24 PM
bossind
1978 - 1996 Big Bronco
Jun 9, 2004 08:30 PM
