Prelubing a FE?
Old Mar 22, 2004 | 03:52 PM
Goobzilla's Avatar
Goobzilla
Prelubing a FE?
What methods do you guys use? Once I get this engine in, I want to prelube it before I fire it off for the 1st time. Thanks in advance!
Ron
Old Mar 22, 2004 | 03:56 PM
d44hd's Avatar
d44hd
The easiest way is to take an old distributor, remove the gear...install it and drive it with a drill, untill you get oil comming out uf the rocker shafts...d44hd
Old Mar 22, 2004 | 04:12 PM
gtex's Avatar
gtex
Since I was replacing the pump shaft with an upgrade part, I took the old pump shaft and welded an appropriate sized socket to the end. I had to gring it down a bit to fit through the distributor hole.
If I remember correctly, it spins counter-clockwise when looking down from the top.
Old Mar 22, 2004 | 09:34 PM
Randyb12's Avatar
Randyb12
A extension for a electric screw driver fits perfectly. If you can't get a 6" extension use two 3" ones. This is how I did it.
Old Mar 22, 2004 | 09:35 PM
Randyb12's Avatar
Randyb12
I forgot to mention that you need to turn the pump counterclockwise.
Old Mar 22, 2004 | 09:58 PM
bassdude's Avatar
bassdude
i bought a shaft to do that it was like 5 bucks at checker. you need a drill with some nuts to turn it though, i used my Milwaukee hole hog and it struggled.
Old Mar 22, 2004 | 10:05 PM
Randyb12's Avatar
Randyb12
I had the extension already. worked fine.
Old Mar 23, 2004 | 03:27 AM
bigric's Avatar
bigric
Use a deep 1/4" chrome socket on an extension and turn the oil pump shaft counterclockwise. It doesn't need to spin that fast; you can do it with a pneumatic ratchet and that will adequately move the oil around after about 30 seconds.
