Modular V10 (6.8l)
Have problems with my V10! need help
Old Mar 22, 2004 | 02:57 PM
cheechf350 dually's Avatar
cheechf350 dually
I'm pulling a toybox (loaded at about 11,500 lbs) with my 99 F350 4x4 V10 dually. Going up hill the RPM goes from 2500 to 5000+ plus my mileage is probably 6 or 7 mpg. I do not have a lift but I do have a roof rack with 3 off-road lights. I put a magnaflow air system, it help but i'm getting a very lousy mileage and not enought power. Does anybody have a suggestions? I appreciated all comments. Thank you!
Old Mar 22, 2004 | 03:02 PM
camo4stealth's Avatar
camo4stealth
You are pushing 18,000lbs. there. Exactly what kind of mileage were you expecting? I roll at 11,000 plus or minus towing my boat and I get 10-11. At 70mph.
Old Mar 22, 2004 | 03:06 PM
cheechf350 dually
my main concern is not really the mileage but the power problem. Why do I jump from 2000 rpm to 5000+ when going up hill (not a big hill) just want to know if is a transmission problem or the v10 doesn't have power?
Old Mar 22, 2004 | 03:15 PM
Big Orn's Avatar
Big Orn
The transmission must be slipping...unless it's downshifting.
Is it downshifting?
Old Mar 22, 2004 | 04:20 PM
68 351 bronc's Avatar
68 351 bronc
I also pull a toy hauler. The weight is not the only thing holding you back. The campers are very tall and the wedge shape of the roof makes for a vacume behind the camper. I'm sure you have noticed how above 50 mph you can go down a 5% grade and not use the brakes. I am building an air foil to bolt on the roof at the back to shoot air down behind the camper. I think with some experimenting I can help the air drag problem and make the camper easier to pull.
Old Mar 22, 2004 | 09:53 PM
cheechf350 dually
No! is not downshifting. What is you MPG when pulling your toy box. I'm considering getting a Diesel. Would you guys recommend a diesel or not.
Old Mar 23, 2004 | 07:33 AM
camo4stealth
If I were towing something that heavy, my signature would be DieselDaddy.
Old Mar 23, 2004 | 08:03 AM
Big Orn's Avatar
Big Orn
I pull around that with my V10 occasionally, but it's a 5 speed manual. I have to take it out of OD when going up a steep hill.
I can't figure why your RPM's jump so high without downshifting?
If you towed that weight regularly, a PSD would be in order.
Old Mar 23, 2004 | 11:12 AM
cheechf350 dually
Thank you every body for your input. Appreciated! I will hate to get ready of my V10 but due to the load I might have to go for a diesel
Old Mar 23, 2004 | 04:04 PM
68 351 bronc
Mine is a 24ft Ragen built by National RV out of California.
Freeway driving at 60mph It gets around 9mpg leaving it in third gear.
I live in the Northwest where if your not pulling a hill your probably going down one.
If I want to go 70 mph it will cost Me another 2 mpg.
3.73 gears, 4X4, extra cab, camper fully loaded
Old Mar 26, 2004 | 08:42 PM
RichF350V10's Avatar
RichF350V10
You said your F350 wasn't downshifting, but you didn't say if it was a manual or A/T. Since an A/T would downshift under such a load if it needed to, it sounds like you must have a manual transmission. If you see the RPM go up and the truck doesn't accelerate, I would guess that you have a clutch that is slipping. Fixing the clutch would fix the problem.
Old May 23, 2004 | 02:34 PM
leonjuplinger's Avatar
leonjuplinger
My 99 E-450 Class C MH with 4.63 gears and auto tranny pulling a car (total weight about 20,000) gets between 8 and 9.5 mpg at 60mph.
Old May 23, 2004 | 02:52 PM
mrwizard's Avatar
mrwizard
2500 RPM to 5000+ RPM is either a different gear or some serious slipping in the tranny.
Old May 23, 2004 | 04:54 PM
Fishin Technician's Avatar
Fishin Technician
I just pulled my 26 foot Sprinter (7800 lbs empty) up I-87 in New York up to exit 26 and went over tongue mtn..........02 f350, v10, auto, 3:73's.......2nd, 4300 RPM'S + THEN SOME.........the grade is known as the "stairway to heaven" windy curvy and steep for 9 miles.....35 to 45 mph and screaming all the way........the v10 loves high revs......
Dan / ft
Old May 23, 2004 | 08:53 PM
Mud Doc's Avatar
Mud Doc
cheechf350dually:
I had an '02 V10, auto, 4x4 with 4.30 gears. I would pull a 9000# trailer very nicely, but never got over 9 mpg, usually 6-8mpg. With the 29 gallon tank, it was a real hassle to keep stopping for gas. Solution? Bought an '04 exact same truck with a 6.0 and 3.73 gears--now I'm getting 10-11 mpg on fuel that is 10-30 cents/gallon cheaper.
It still isn't that great between fule stops, but 250 miles/tank is sooooooooo much better than 150 miles/tank. Solo, where I do the most driving, is 16-18 mpg.
Go to the 6.0, you won't regret it.
