E150 Econoline VAN 5litres V8
Old Mar 22, 2004 | 01:56 PM
limpel's Avatar
limpel
My van starts up. Then the rpm's go up and down till she stops. The only way to keep her running is holding the gas pedal down. As soon as I take my foot of, she quits.
Has somebody any hints where to look for?
Old Mar 22, 2004 | 02:01 PM
EPNCSU2006's Avatar
EPNCSU2006
Start by pulling the codes. http://fordfuelinjection.com - click on "Getting Codes" on the left side of the screen to find out how to do it your self.
Old Mar 22, 2004 | 11:37 PM
fordberg's Avatar
fordberg
There is and motor operated solenoid that controls the idle speed. On the solenoid there is a bolt that can be screwed in and out.
Old Mar 23, 2004 | 11:57 PM
c96drumm's Avatar
c96drumm
The solenoid is the IAC. (Idle Air Control) It can be removed and cleaned with throttle body cleaner. It cannot be adjusted. That could be the problem. Another suspect would be the TPS. (Throttle Position Sensor) First, as EPNCSU2006 says, pull the codes. How long since tuneup?
BTW, what year is that van?
