ignition switch
Old Mar 22, 2004 | 11:37 AM
desertdave5's Avatar
desertdave5
ignition switch
how do you remove the old key switch in a 95 f-150?
Old Mar 22, 2004 | 11:47 AM
gasman6674's Avatar
gasman6674
Disconnect the battery, Turn old key to run position, Push the pin from on the bottom of the column(you may want to drop lower shroud), Pull it straight out. Put new key switch in run position and put it in, reconnect battery. The haynes manual has the procedure in a little more detail along with Pictures. Hope this helps
