Sponsored by: Auxito
need to reset a computer need help
Old Mar 22, 2004 | 09:28 AM
whitelightning2004's Avatar
whitelightning2004
does anybody know how to reset the computer on a 99 ford truck do i have to diconnect the batery or is there a easyer way thank you
Old Mar 22, 2004 | 10:26 AM
Mike W's Avatar
Mike W
Disconnect the battery for 15 min.
Old Mar 22, 2004 | 07:47 PM
bosshoss's Avatar
bosshoss
Hey.
You can have autozone scan for codes. then do a clear, or reset as you would put it.
Old Mar 22, 2004 | 08:49 PM
JustinH's Avatar
JustinH
on my 96 tbird there is a fuse in the underhood fusebox labled EEC, pull this then crank the car, then replace it.
That will reset the eec.
I'm not sure if the trucks have a similar deal, but if they do then this is alot faster than getting out the tools to disconnect the battery.
JH
Old Mar 22, 2004 | 10:02 PM
LxMan1's Avatar
LxMan1
Resetting the codes with a scanner will not totally reset the PCM. It lose power to clear the driving habits that it has learned. Either by removing a fuse or unhooking the battery.
