Does this seem right?
Old Mar 22, 2004 | 07:31 AM
tuono's Avatar
tuono
I think I have a fuel system problem, when the 460 in my 78 ford is cold or warming up the fuel filter is completely full. After driving it for a while it starts to miss a little and when I look at the filter it is now almost empty and just a little fuel is squirting into it. Any ideas?
Old Mar 22, 2004 | 09:04 AM
fordtime's Avatar
fordtime
Check your rubber fuel lines.
I had a simular problem, the fuel line that goes to the pump from the hard line was bad.
Vince
Old Mar 28, 2004 | 09:56 PM
Polkat's Avatar
Polkat
Is your filter before or after the pump? If after the pump, check the pump pressure. Does the gas tank cap have a vent (some don't). If so, check that it is clear. And as others have said, check all the rubber lines, both before and after the filter.
Old Mar 29, 2004 | 12:00 AM
LxMan1's Avatar
LxMan1
Mine have always done that. Checked the pressure on my 63 and even with the filter almost empty, it still has 6psi.
