89 F250 front fuel pump problem
Old Mar 22, 2004 | 12:33 AM
dave_Kov's Avatar
dave_Kov
I have an 89 F250 460 FI, and I'm hoping someone can help me diagnose a fuel system problem with my front tank.
Whenever I switch to the front tank, the motor dies in about 10 seconds. Also, when I turn the key to the ON position, I can hear the pump run for a few seconds, then it shuts off. I guess this is correct, but this rules out a bad fuel pump, right? The few seconds that the pump runs provides enough fuel to start the motor for a few seconds, but then it dies. Since the rear tank works fine, does this mean that the inertia switch isn't thrown?
Thanks in advance for your help.
Dave
Old Mar 22, 2004 | 12:37 AM
EPNCSU2006's Avatar
EPNCSU2006
If you hear the pump(s) run, then the inertia switch isn't tripped. I'm not sure if an '89 still has 3 fuel pumps or not. If so, then the in-tank pump could be bad and it's just running out of fuel. If there is a fuel pump on the frame rail (in the fuel line) you can unplug it, and then listen for the in-tank pumps to kick on with the key. Try it on both tank positions on the switch to test both tanks.
Old Mar 22, 2004 | 10:55 AM
AJ Goss's Avatar
AJ Goss
You need to determine if your truck has two fuel pumps or three. My guess is two, going from what you describe. It sounds like the fuel pump in the front tank is dying.
Ford fuel pumps don't suddenly die. They die a slow, gradual death. Just because you can hear them run doesn't mean they work.
Old Mar 22, 2004 | 11:33 AM
cbeaur's Avatar
cbeaur
Had the same problem with my 89 F350 with the 460, has 2 fuel pumps. Replace the pump I gurantee its crap, mine would turn on and sound like it was fine just like you had described. Guess what its not good, just replace it and you shouldnt have a problem, famous last words.
Old Mar 22, 2004 | 12:02 PM
EPNCSU2006's Avatar
EPNCSU2006
It's possible for sure, but electric fuel pumps usually work or they don't - electric pumps in general, not just Fords.
Blueriver16
Sep 7, 2016 07:31 AM
tylerz71
May 29, 2016 05:39 PM
tony_corbin
Mar 5, 2014 09:35 PM
daveandmoe
Jan 29, 2014 05:58 AM
Vosko
Dec 21, 2004 10:41 AM
