speedometer bouncing
Old Mar 21, 2004 | 08:26 PM
butch a 250 d's Avatar
butch a 250 d
i have a 94 non turbo auto 4x4 with a factory ltd slp rear dif my speedo will jump up and down on ocason
i have chnnged the oil and had it looked at does not seem to be any obvious prblem we have cleaned the sensor pikup in the dif case
butch
Old Mar 22, 2004 | 05:03 PM
nogo73's Avatar
nogo73
you need a new speedometercable
Old Mar 22, 2004 | 05:27 PM
bchunter's Avatar
bchunter
Funny enough, mine did that last winter, but it only did it when it was cold outside. I also had an old chev that the speedo would bounce when it was cold outside as well. Except for the winter, my speedo doesn't bounce, and I have a 93 F250 non turbo. The guys at the shop told me that I may need a new speedo panel, but it costed too much, so I havn't done anything yet. If it is just the speedo cable, then that should be a fairly cheap fix. Good luck.
Old Mar 22, 2004 | 08:56 PM
redneckmechnic's Avatar
redneckmechnic
mine did that and i needed a new gear that goes on the end of the cable got one out of the junkyard for a buck. ford wanted somthen like 45 bucks.
