Sponsored by: Real Truck
Locking hubs
Old Mar 21, 2004 | 07:49 PM
fireftnford's Avatar
fireftnford
Locking hubs
Question,
Will it hurt the hubs if you leave them locked in??? We have a superduty that is going to be used as a field piece(fire truck). We would like to leave them locked in for the convenience of not having to get out of the truck and locking them in everytime we go off road. The longest distance we will travel on paved surfaces is about ten miles.
Old Mar 21, 2004 | 08:02 PM
78fordman's Avatar
78fordman
thats fine, most people leave theirs lockin the winter anyhow. In at holloween and out at easter, i was raised by that sang.
Old Mar 21, 2004 | 09:07 PM
Yeti's Avatar
Yeti
Like 78 said, won't hurt anything, of course there is always the argument of more wear, but I say better to use them than let them sit.
Mine get locked oct 31st and unlocked April 1st...
Old Mar 21, 2004 | 10:06 PM
cwb's Avatar
cwb
What if it snows on April 2nd?
Old Mar 21, 2004 | 11:17 PM
LilBlackCoupe's Avatar
LilBlackCoupe
Doesn't that stress the u-joints?? Premature wear??
Old Mar 22, 2004 | 01:32 AM
04superduty's Avatar
04superduty
The wear will be mininal. On dodges the front u joints always spin since there are no hubs. Milege will suffer alittle from the extra drag.
Old Mar 22, 2004 | 06:09 AM
Yeti's Avatar
Yeti
Who cares I'll be in SoCal
My contracts run until and include 3/31.
Old Mar 22, 2004 | 06:50 PM
fireftnford
Thaks for the input. I don't think wear will be an issue, either. Our old truck is a 78 Dodge power wagon and it only has 8000 miles on it. Then we have our "old brush truck".... a 52 dodge military surplus pickup. Still going. We have this new truck loaded with a 300 gallon tank and pump assembly. The power stroke pulls like the truck is still empty.. One more question... Can we get a set of 285/75/16's on the OEM 16x7's with no problem????? The stock tires are a little weak looking. Thanks again for the insight.
Old Mar 22, 2004 | 06:58 PM
78fordman's Avatar
78fordman
I think you should be fine on the rims.
Old Mar 22, 2004 | 07:01 PM
fireftnford
Thanks 78 fordman. I have looked at the spec sheets on the tires and you only lose 105 lbs of load per tire when you go to the bigger tire. The only thing is, the maximum pressure goes from 85 psi to 65 psi. Will that make any difference in the way the truck handles the load???
