mustang injectors
Old Mar 21, 2004 | 03:25 PM
xlt85's Avatar
xlt85
Question mustang injectors
I have a 1985 F150 xlt EFI. I was wondering if EFI mustang injectors will fit the truck efi. Iam looking for a little more grunt for the old girl. thanks
Old Mar 21, 2004 | 06:01 PM
Stompjackson's Avatar
Stompjackson
I can tell you that mustang injectors are high impedance 19lb/hr injectors. Cobras have 24 lb injectors. What I don't know is what came stock in your truck. That is also what I'm trying to find out about my dad's truck.
Also, your ECM is calibrated to work with the stock injectors. If you install injectors that flow more or less than stock, then you will get more or less fuel flow than the computer expects. That wont be good. you will have to adjust fuel pressure to try and compensate. I would install new injectors if you thought the old ones were bad but I would definately install new ones with the same flow rate as the stock ones.. Also, I think your truck is a speed density system which is even less tolerant of mods than a mass air system.
Hope that helps,
Eddie
Old Mar 21, 2004 | 07:24 PM
fordnut71's Avatar
fordnut71
the mustang an truck 302 injectors are both 19 lb injectors . so a swap wouldnt do any difference for u there
Old Mar 22, 2004 | 03:40 PM
xlt85's Avatar
xlt85
i found out that the f150 injectors are 15 lb and the mustang gt is 19 lb. I think i will maby try to snuf a 4.6 in instead and mess with the harnes bscause the truck is a pig on gas with the 5.0. truck is to good to scrap. thanks for all your help
Old Mar 22, 2004 | 05:20 PM
fordnut71's Avatar
fordnut71
the 300 has 12 # in iut the 302 has 19 # an the new mod motor injectors had a different plug on it so it cant be used . if u having a problem with fuel milage i would be looking else where with the motor iv had 1 that i could drive from toronto to casino rama for $ 8 on the high way an it a 86 was 302 with a auto extended cab
Old Mar 22, 2004 | 05:28 PM
xlt85's Avatar
xlt85
Thanks guys . i had a 1984 f150 ext long box could go from whitby and back on $20.00 thats a 3 hour round trip . the 85 goes to barrie and back 1.5 hour round trip $30.00 the motor has 206kms on it i think it is a dud
