Chaging fluids in trans and transfer case
Old Mar 21, 2004 | 01:18 PM
FARM69's Avatar
FARM69
I have some extra time on my hands and wondering if I should change the fluid in my transfer case and transmission. The truck has aboutr 140,000 miles on it.
Is there any precautions or guidlines that I should follow when I do this?
What weight of gear oil should I use?
____________________
90' F150 xlt 4x4 302 4-speed w/ 4.10 rear
Headers/true duals 2.25" w/ 28" glasspacks coming out at 45's
Old Mar 21, 2004 | 01:33 PM
hoxiii's Avatar
hoxiii
Can't hurt to chage it.
The 4 speeds all use gear oil. If it's a granny gear unit it'll take almost a gallon, if it's an OD unit i'm not sure.
If the T-case has an aluminum housing, it uses ATF. IF it's cast iron it uses gear oil. Unless te case has been swapped out, it'll use ATF.
Justin
Old Mar 21, 2004 | 01:41 PM
FARM69's Avatar
FARM69
Yeah thats what I was thinking. Man, a gallon thats quite a bit. Is there a plug or do I have to unbolt them. I guess I haven't looked at the tranny yet but I don't think there is a plug on the case.
Is ATF just a general product or do I have to order the correct weight?
Old Mar 21, 2004 | 05:19 PM
hoxiii's Avatar
hoxiii
ATF is automatic transmission fluid, it's all the same. There should be two plugs on the tranny case, one low and one about 1/2 way up. low one is drain, high is fill/check. fill through the top hole until it starts to come out the same hole.
Justin
Old Mar 21, 2004 | 10:14 PM
FARM69's Avatar
FARM69
Is that the same procedure for the tranny too?
