spark plug color
Old Mar 21, 2004 | 10:37 AM
handx2's Avatar
handx2
spark plug color
my truck has a miss to it.i pulled out the plugs and cleaned them.they ranged in color from white,orange,brown,to black.why so many colors and what color should they be?
Old Mar 22, 2004 | 09:41 AM
Mike G's Avatar
Mike G
Whats the details on the engine? Ideal plug color is sort of a light dry grey, a little discolored from original. Sounds like you need to change plug wires or do a compression check. Where they wet as in oily or did they smell like gas? Looks like your white ones are probably running the best.
--Mike
Old Mar 22, 2004 | 12:20 PM
handx2's Avatar
handx2
it was recently rebuilt,but i`m not sure it was done right.it has cheap 7mm wires on it now,with autolite plugs.i`m going to replace the plugs and wires soon.i also want to check the compression as soon as i can get my hands on a comp tester.what kind of plugs and wires would you recomend?the inside of the plugs were dry,but the threads had oil on them.
