Sponsored by: Auxito
need help to remove and replace drivers side power window motor
Old Mar 21, 2004 | 10:12 AM
jerrymc1216's Avatar
jerrymc1216
The existing motor for the power window in my 1997 Ford F150 seems to be riveted in with no apparent way to remove and replace without torching off rivets or something drastic. Has anyone experienced or solved this problem for a DIY enthusiast?
Old Mar 21, 2004 | 10:30 AM
Racerguy's Avatar
Racerguy
Hi Jerry and welcome to the forum
There are 3 bolts holding the motor to the window regulator.
To access them you have drill holes in the door so you can get a socket it. There are dimples in the door to show you where to drill. The manual says to drill 3/4" holes but I've used smaller. It just depends on how thick your socket is.
