Aerostar Ford Aerostar
Blower Motor
Old Mar 21, 2004 | 05:48 AM
GoneFishen's Avatar
GoneFishen
Angry Blower Motor
Time to replace the blower motor. Normally a 10 minute job, but the accumulator for the A/C prevents the motor from being removed. No amount of twisting or turning will clear it. I don't want to disconnect any A/C lines if I can help it. Has anybody else had this problem?
Old Mar 22, 2004 | 02:30 PM
BarryFS's Avatar
BarryFS
The blower motor can be nudged out, if all the bolts are taken off that accumulator, and the air cleaner is removed. Bit of a squeeze.
Old Mar 23, 2004 | 08:45 AM
himthere's Avatar
himthere
did mine. tight, and a little twisting involved, but it will go. I didnt have to do anything to the ac. 94, 3.0
Old Mar 23, 2004 | 07:04 PM
ha38349's Avatar
ha38349
Did mine also, 90 3.0 with A/C. It took a bit of work, almost as bad as doing the spark plugs. Did not have to disconnect any A/C lines but you have to take out the bolts on stuff to give yourself just that extra bit of clearance needed.
Old Mar 31, 2004 | 06:08 AM
GoneFishen's Avatar
GoneFishen
Thanks all, took your advice and did manage to get it out. Imagine my surprise to find a squirrel nest in there, debris had gone thru the cooling tube into the motor and that was the end of that. I believe from now on, I'll go out of my way to run over squirrels.
