adding a supercharger
Old Mar 20, 2004 | 07:21 PM
bill6302's Avatar
bill6302
i have been looking at a powerdyne supercharger for my 92 f-150 5.8. i was just wondering what was involved in installing it and if i need to make any major engine modifications. i figured i would need new injectors and fuel pump and mess with the timing, but is there anything else other than that? any help is appreciated.
bill
Old Mar 20, 2004 | 10:28 PM
Blurry94's Avatar
Blurry94
For the money it's a pretty decent kit, and should come with everything you need. You'll need to back the intial timing down a couple degrees to prevent detonation. Or, you could leave the timing where it's at and run a boost retard.
The injectors will be fine for a 6-8psi kit since it comes with an FMU, but if you're going to replace them then get a larger set, like 30's. With larger injectors you'll need some type of tuning so they'll work with your computer. In any case, a dyno tune would be the best way to tie everything together. I'd also recommend running a bypass valve....I don't think the kit comes with one.
Old Mar 20, 2004 | 10:34 PM
bill6302's Avatar
bill6302
alright, thanks. will my engine parts hold up to the supercharger or do i need to upgrade them?
Old Mar 20, 2004 | 10:41 PM
BLEGOAT's Avatar
BLEGOAT
Sorry,
I got there info packet yesterday in the mail. It comes with a video.
All you have to do is install the thing and that is it. No computer change, or timing change or anything.
Call or e-mail them.
Old Mar 20, 2004 | 11:03 PM
bill6302's Avatar
bill6302
what exactly does a bypass valve do also? and how easy/hard is it to install?
bill
Old Mar 21, 2004 | 12:40 PM
ubeenbit's Avatar
ubeenbit
A bypass vavle bypasses air from the discharge to the suction of the supercharger. Basically, it is a way of controlling discharge air temps when normal cruising and it helps to limit boost between the discharge of the supercharger and the throttle body. Another beneift of a bypass is for high boost or IMO any boost, when the throttle closes after a hard run or during a shift, it provides a route for the compressed air to relief to. Otherwise the impeller will try and stop and other bad things can start to happen. If your kit does not come with a bypass valve I highly recommend getting one.
Old Mar 21, 2004 | 03:20 PM
Blurry94's Avatar
Blurry94
Since your truck is SD (I think), then you can just vent the bypass valve out into the atmosphere because the air isn't "metered" like a MA truck.
Old Mar 21, 2004 | 08:55 PM
bill6302's Avatar
bill6302
ok, thanks. blegoat, where did you get the info packet from?
Old Mar 21, 2004 | 10:06 PM
BLEGOAT's Avatar
BLEGOAT
www.ProCharger.com
Old Mar 22, 2004 | 10:27 AM
Blurry94's Avatar
Blurry94
Originally posted by BLEGOAT
www.ProCharger.com
Wait a second here....A Pro Charger and Powerdyne are completely different kits...even the comperessors are of different designs. Most of the Pro Charger kits come complete with a bypass valve, and even an intercooler, that is why they are more of a bolt-on and go type of kit (as well as more $$). With an intercooler, you wont need to run a timing retard. The powerdyne kit does not come with a bypass valve or an intercooler, so you are talking about two diffferent kits, and two different compressors.
Edit: Come to think of it...I'm not sure if Pro Carger makes a factory kit for pre 96 Ford trucks, Unless one of their dealers is making their own custom kits for these trucks.
Old Mar 22, 2004 | 02:04 PM
BLEGOAT's Avatar
BLEGOAT
My bad, reading to fast again.
Also, It says that 97 is the cut off for the Ford truck, but you could call.
With the ProCarger, everything has to do with the intercooler. That is how they get away from not have to mess with the computer or the timing.
My bad on the miss understanding.
B
