Aerostar Ford Aerostar
Brake Fluid Leak from Equallizer
Old Mar 20, 2004 | 03:03 PM
billygoatvan's Avatar
billygoatvan
Question Brake Fluid Leak from Equallizer
Vehicle info: 1995, 4.0L AWD, w/rear ABS
I've located a brake fluid leak from what appears to be an unused end port on my equallizer (proportioning) valve (prior to the ABS, after the master cylinder) This end port is capped but the cap has a 1/16" dia hole in the center of the cap. Fluid leaks from here when pedal is fully pressed. The cap is not rusted, it just has this clean (almost machined looking) hole in it !
Is this cap missing another plug of some kind or is it a rupture disc or is it a bleed hole indicating my equallizer valve is shot.
Service manual not providing any help.
Thanks for any assistance.
Bill
Old Apr 1, 2004 | 01:00 PM
moneyPit's Avatar
moneyPit
I has the same problem, there is a ruber plug that should be in there. I raplaces the valve with one from scrap yard, 2 yrs ago - still stops...Bleeding the brakes is the hard part!
Old Apr 2, 2004 | 08:50 AM
yendor's Avatar
yendor
billygoatvan IF you go down to the thread( right back brake is locking up )there is a site on that thread that will tell you a lot about this valve.
