O2 Heater sensor circuit codes
Old Mar 20, 2004 | 01:55 PM
fb_rider's Avatar
fb_rider
I recently purchased a 1996 F150 5.0L truck and after a couple of weeks the check engine light went on. The codes are P0135, P0141, and P0155 - all O2 Heater circuit errors. I replaced both O2 sensors and the reset the light. It was fine for about 500 miles, now the light is back on and I am getting the same codes. I've heard that the PCM may need to either be reprogrammed or replaced - any ideas?
Old Mar 20, 2004 | 10:45 PM
EPNCSU2006's Avatar
EPNCSU2006
The heater of the O2 sensors gets power from the ignition switch, probably through a relay on a '96. I haven't dealt a lot with trucks that new, but I know on some of the wiring diagrams I've seen have a relay for the mass air meter power and O2 sensor heater power wires. I'd look for that and see what you can turn up.
sweetace1
Apr 24, 2014 06:43 AM
j2007
Aug 16, 2011 08:04 PM
widebody95
May 29, 2011 06:07 PM
88PONY
Oct 23, 2009 08:44 AM
geoaigel
1983 - 2012 Ranger & B-Series
Jan 10, 2005 10:50 AM
