Replaced front pads and rotors. When stopping from speed all works well until I get to the (15-5) mph. the abs system goes off, almost like I were in snow or ice. Other than that, all is fine.
Also when looking at the abs test plug, the manual says to jumper pin "a" to "e" in order to read out any codes. One problem, the test connector is NOT labeled, so I don't know which ones are pin "a" or "e" Any help?
