1978 - 1996 Big Bronco
Automatic Hubs...
Old Mar 19, 2004 | 04:00 PM
InLoveWithGreta's Avatar
InLoveWithGreta
Automatic Hubs...
i've heard good things and bad things about the automatic hubs...anyone out there got any sort of experience with them that i might want to know about? they're on my "hmm, maybe i should replace this" list of parts and i'd like to get some opinions before i tear up something i don't need to tear up. and if i need to use them for paperweights, what's the best replacement (aside from a Dana 60 )?
Old Mar 19, 2004 | 04:46 PM
WhëëlMå1's Avatar
WhëëlMå1
You must do a search for auto hubs. I would have to say that is the most commonly talked about issue in this forum. To sum it up, the ford autos are complete crap. They are unreliable, and a fortune to replace. A simple pair of Warn (or equivelent) manual hubs will provide you years of unwavering service. I swapped my autos out a year ago, and I have never looked back.
Rich
Old Mar 19, 2004 | 04:50 PM
BOJOFASO's Avatar
BOJOFASO
auto hubs are convenient . i have not had any problem with mine in 122,000 miles. a lot of people say they are not reliable and if you are goinng to use the truck for hard core 4x4 you will probably break them. they cannot handle the forward to reverse under power that is sometimes needed when wheelin. if you are only going to do some light wheelin you should have no problem. it is only a 70.00 conversion to change to manuels and that is cheap insurance to know that your hubs are locked in.
i have a brand new set of warn hubs sitting in the garage waiting for the one time that the hubs fail me. but until then im going to run with the auto hubs.
Old Mar 19, 2004 | 07:41 PM
InLoveWithGreta
well, i didn't see a lot of opinions either way, so i thought i'd ask. thanks for the replies.
Old Mar 19, 2004 | 07:47 PM
buckinbronco'95's Avatar
buckinbronco'95
i have yet to have a problem yet in the past 8 years with my auto hubs... as soon as i do tho im switching... but dont fix what aint broke
Old Mar 19, 2004 | 09:16 PM
WhëëlMå1's Avatar
WhëëlMå1
I thought the same thing, until I got myself and my family stuck. Talk about a feeling you really dont want to have. The pre-emptive measure is well worth it in some cases.
Rich
Old Mar 23, 2004 | 03:14 PM
RVCams's Avatar
RVCams
The most common problem with the auto hubs is that they are mistakenly packed with grease during a brake or bearing job. Ford says that they should be cleaned, dipped in transmission fluid, then inserted.
I "acquired" two sets of auto hubs from other forum members who claimed that the hubs were bad. Both sets arrived throughly-packed with grease. I cleaned and soaked each of them and then tested them in my truck. Both sets worked perfectly.
Some on this forum will argue otherwise, but as far as I can tell, the vehicle has to be moving for the hubs to completely engage. If you wait until you're stuck, then it's too late.
Old Mar 23, 2004 | 06:17 PM
BOJOFASO's Avatar
BOJOFASO
the truck does NOT have to be moving for the hubs to lock in all that has to happen is that the front driveshaft must spin or the hubs will not lock in. the front wheels DO have to move in the reverse direction for at least 2 revolutions to unlock the hubs.
i have checked this info with my ford tech freind. he also tells me that the hubs lock and unlock and then relock when you shift from forward to reverse and that is what makes them a weak point in the 4x4 system. but for normal 4x4 and no heavy wheelin they are a perfectly competent component.
Old Mar 24, 2004 | 08:57 AM
jimandmandy's Avatar
jimandmandy
True, to a point. According to the 1993-1994 Ford manual they do need to be greased. "Repack the [cap] bearing with a lithium base grease... Lubricate the brake band and drag sleeve assemblly with 1.5 grams (0.5 oz) of Automatic Hublock Grease [part # and spec], or equivalent." The ATF "dip" is for the main body only, not the greased parts. The problem is that some people think that if a little is grease is good, a lot is better.
Jim
Old Mar 24, 2004 | 11:09 AM
Ben242's Avatar
Ben242
I didn't know mine were broken till I went to the beach and ALMOST got stuck in the sand. Good thing I have 35x14.5 ssr superswamper tires. Man was I ****ed. I replaced with superwinch manuals, and almost threw the autos in the Ocean, but that wouldn't be nice now would it
Old Mar 24, 2004 | 11:30 AM
jambroson's Avatar
jambroson
I sure loved my Automatic Hubs. When the truck had 60,000 miles on it would make a quick U Turn and the hub would try to engage itself. Hubs finally bit the dust on a hunting trip. I went over a hill and wound up in a patch of Sand bogged down.
"Don't worry everyone." I put the Bronco in 4 Wheel Drive and the real wheels spun.
I can't believe people are extolling the virtues of the worthless crappy Ford Automatic Locking hubs.
If anyone is reading the, please go buy a set of Warns and never look back.
Josh
Old Mar 27, 2004 | 08:21 AM
reddog 95's Avatar
reddog 95
Smile
I have had bad experiences with automatic hubs on my bronco, and on a f-150. Some friends of mine have had problems with them too. I strongly feel they are more trouble than they're worth.
Old Mar 27, 2004 | 08:32 AM
nechun's Avatar
nechun
i sell for a ford parts department. yeah, i would make more selling the auto lockers, but knowing how reliable they are, I tell my wholesale and retail customers to go buy some WARN at a parts store. even the ford manuals are expensive. for what you spend on just the body (locking mech), you can buy everything in a complete kit from warn!
Old Aug 1, 2007 | 06:05 AM
DerekVS's Avatar
DerekVS
Oh, man. Now I'm paranoid.
I use my '94 Bronco (4" Superlift w/33" DC FCII's) primarily for getting to the top of the crater volcanoes up in Flagstaff, AZ for my hang-gliding addiction. The path up is made of loose cinder gravel.
The last time I was there, several brand-new (stock) Dodge and Chevy pickups, and even a Range Rover tried to get to the top and failed, tearing up the trail further. I romped right to the top (a very steep 1,200 ft. climb) and my girlfriend drove it back down after I launched, all with the factory auto-lockers. The thought of my girlfriend losing control on the way down really sucks.
I'm buying some Warn premiums right now - I have the order web page up... Anyone wanna buy my currently working stock autos?
Josh
Old Aug 1, 2007 | 07:09 AM
WhëëlMå1's Avatar
WhëëlMå1
Welcome to FTE. You are better off fashioning them into paper weights, than trying to sell them.
