ok firs to all thanks great sight.
also sorry my typing stinks lol.
ok now for the question? I have seen several mentions of power windows in here a few years ago i took a spair door and skined it and tried 3 or 4 difrent power window combinations ( ok driving the wreaker for the local bone yard and building 2 demolition derby cars a year helps with parts) i couldnt get any to work right. Is there an aftermarket kit or do you have a spicific doner to use for parts.
yota, What problem were you running into? If the motor mounted and you install the three way switch, it should work.
I did have a listing for a kit on my old puter that I might look up for you. I have some motors that I have pulled from a van that I hope to use one day.
at the time i couldent get the gear to mesh up right it would bind 1/2 way up havent played with it in a wile was wondering if any one had done it successfully and if they had pics?
