Brake's > wheel lock-up
Old Mar 19, 2004 | 01:02 PM
Kaela's Avatar
Kaela
The title has been changed to reflect the topic
So heres my problem!!
I just got the brakes done on my truck a week ago...and they have been fine. Now I put the brake on and for some reason the one rear wheel locks up even when I very lightly apply the brakes....I have no Idea what is going on but I am damn frustrated!!
If you guys have any idea what may possibly be going on I would love you help!
kaela
oh yes and to make matters worse my hood wont open.
Old Mar 19, 2004 | 01:10 PM
68torino's Avatar
68torino
It sounds like the wheel cylinder may be bad and not releasing or when the brakes were done the brake adjuster parts were not cleaned and lubed. All easy fixes. You can remove the drum and remove the shoes and parts and clean them and lube them up. Not the shoes of course.
Then I would use a graphite lube for the adjuster which is the item at the bottom with the star wheel. Add some graphite lube to all piviot points. Lookthe wheelcylinder over and see what shape it is in. If it looks old I would replace it and the one on the other side. Also I would do a complete brake fluid flush.
Time consuming but well worth the sense of confidence when you apply the brake instead of
Old Mar 19, 2004 | 01:30 PM
78fordman's Avatar
78fordman
Make sure none of the lines are kinked or anything. Also check adjustment on the shoes, tighten the star until the drum barely starting scraping.
Old Mar 19, 2004 | 02:32 PM
CodaSmog's Avatar
CodaSmog
As far as your hood not opening, try pulling the handle with your right hand and push down on the hood with your left real hard, you should hear it click, then while still pulling on the handle lift up the hood with your left hand.
Hope this works, It's what I have to do everytime.
J
Old Mar 19, 2004 | 06:54 PM
Mil1ion's Avatar
Mil1ion
What if she is left-handed ?
Old Mar 20, 2004 | 12:51 AM
Phinxter's Avatar
Phinxter
Am I missing something here, She said she had the brakes done. I will make the assumption somebody other than her did the job, and after only a week she needs to take it back and fixed, If the job was done right there would be no problem, IE bad wheel cylinder, kinked lines, lack of grease etc.
fl-mitchells
16
Mar 15, 2013 01:43 PM
focusdriverlx20
Jul 7, 2010 02:50 PM
dragster557
Jul 6, 2010 05:26 AM
f350lord
16
Oct 12, 2009 08:29 AM
dewking
1983 - 2012 Ranger & B-Series
May 5, 2009 08:21 PM
