Sponsored by: Real Truck
V10 top speed
Old Oct 8, 2000 | 10:37 PM
dan4x4's Avatar
dan4x4
V10 top speed
Hey all,
What is the top attainable speed on a stock V10 (in a 250/350 4x4)? How about a motor that has been chipped? I am not a speed fanatic, but this engine must have some impressive potential...
Thanks,
Dan
Old Oct 9, 2000 | 07:38 AM
kaution's Avatar
kaution
V10 top speed
With no chip the top speed for any superduty is 95, 96. This is when the goviner kicks in. I know that a V10 and V8 have the same cut off point.
Old Oct 10, 2000 | 12:30 PM
SuperPleased's Avatar
SuperPleased
V10 top speed
>Hey all,
>on a stock V10 (in
>chipped? I am not a
This is a moot question,Dan, for two reasons:
1. The computer limits top speed to ~95mph. And, while a Superchip will remove that limitation, and
2. The LT tires will disintegrate (and probably kill both you *and* you Super Duty)long before you reach top speed that the engine could produce. I don't know of a high-speed LT tire. If anyone does, please let me know.
Tom
Old Oct 10, 2000 | 07:29 PM
wawii's Avatar
wawii
V10 top speed
On the Dyno the truck hit 130+
On the road it's done a 100+
Yes, I have a SuperChip
Old Oct 14, 2000 | 01:23 PM
devan's Avatar
devan
V10 top speed
>Hey all,
>on a stock V10 (in
>chipped? I am not a
>Thanks,
>Dan
95 is it with the ford, however my 96 dodge V-10 would top out at 112 mph.
Old Oct 18, 2000 | 03:39 PM
richard1's Avatar
richard1
V10 top speed
I bought a Superchip for my 98 5.4 4x4 and it did nothing, took it out and it is sitting in the garage. Turns out they are pretty useless with the 5.4. I just bought an Excursion with the V-10, love that engine...did the Superchip make that big a difference when you installed it in the engine..and which wrapper(vehicle) do you have with the V-10? Thanks for the info
Old Oct 27, 2004 | 12:41 PM
dyarumian's Avatar
dyarumian
in a '02 4x4 with the V8 the goviner won't let you do more that 97.5 so set the cruse control at 95. BTW the highway is long, straight, and deserted in northern Maine. Chevys go to 100 but the govener shuts the whole truck off, Ford just wont let you go any faster.
Old Oct 28, 2004 | 07:29 PM
mizzitch's Avatar
mizzitch
My 1999 V-10 will do well over 100mph. I used my hypertech programmer to remove the governor. It takes longer to get over 100 with 20" rims and 33" tires, but with the factory 265/75R16 sized Dueler Revo's it gets to 100 quick. The needle goes down past 100 slowly, then at about 115mph the needle drops to the bottom of the instrument panel and is pegged there. If you are going even slightly down hill, it gets going faster than one wants to go in a 7000# truck. I've probably gone a little over a buck twenty.
Old Oct 29, 2004 | 11:38 AM
basstardo's Avatar
basstardo
My cousin is a Deputy Sheriff in Ohio and he was telling me a story about a chase he was involved in with a F250 V10 that was supercharged. Not sure what all else was done with the truck, but he said the truck was paced and clocked at speeds of up to about 135-140. The guy eventually blew the tires out because they couldn't handle the speed. The worst part from what he told me is the guy driving the truck was drunk, and it wasn't even his truck, it was his brothers...and it still had temp tags.
Old Oct 29, 2004 | 12:04 PM
V10KLZZ71S's Avatar
V10KLZZ71S
120+mph in mine,5620# truck.
Old Oct 29, 2004 | 04:15 PM
ktm520mxc's Avatar
ktm520mxc
I have a Hypertech programmer for my 2000 V10. How did you get past the govenor?
Old Oct 29, 2004 | 04:58 PM
V10KLZZ71S's Avatar
V10KLZZ71S
SUPERCHIP TUNER: Remove speed limiter? Yes/No
Old Oct 29, 2004 | 05:20 PM
mattsf250's Avatar
mattsf250
pretty much all vehicle manufacturers limit speed at whatever the max speed rating of the tire they equip them with from the factory are rated at....
Old Oct 29, 2004 | 06:15 PM
Autobahn F-250 Lariat's Avatar
98mph in the slow lane here
Old Oct 30, 2004 | 07:48 PM
redhawk44's Avatar
redhawk44
hi speed LT tires
BF Goodrich lists a GForce T/A KDW LT325/55R22D Service Code 120H. I think that is a 36x12.5 with a load rating of 3086 lbs and speed rating of 130mph. A SD would look kinda funny with a lift to clear the tires and a tread pattern that looks likes it belongs on a Cobra but it sure could be fun.
dan peters
Sep 25, 2014 12:08 AM
Dan V
Apr 29, 2014 11:36 AM
bachus
Modular V10 (6.8l)
Mar 19, 2014 04:27 AM
danr9745
Mar 14, 2014 10:24 PM
dans 51 f2
15
Feb 19, 2014 09:26 PM
