General Automotive Discussion
posi track
Old Mar 19, 2004 | 05:26 AM
dinah moe's Avatar
dinah moe
Question posi track
I need some information to settle a bet with a friend.
Could anyone explain the difference between posi track and 'regular drive'. And do 4 x 4's have posi track when in 2 wheel drive?
Cheers,
Dinah moe
Old Mar 19, 2004 | 07:24 AM
peppy's Avatar
peppy
http://www.ring-pinion.com/tech/techind.html
read 'carriers, positractions,lockers,spools'
That should answer alot of your questions........
2x or 4x has nothing to do with your differential being an open rear end(regular) or limited slip(Posi). Your diff is what it is. The transfer case and hubs engaged make it 4x4.
Old Mar 19, 2004 | 10:38 AM
mtflat's Avatar
mtflat
I know you won't find it on a Ford
Posi is a Chevy term.
Try trac lock or limited slip.
Std carrier allows power to go to the wheel with the least traction - not good when one is in mud or on ice.
Ltd slip allows them to function like a std carrier until one side starts to spin. It then 'locks' the two sides together temporarily giving equal traction to both wheels.
A true locker locks the axle into a solid unit - which is not good for turns on pavement.
This is a real rough description but it gives you an idea. As peppy said, 2x or 4x makes no difference.
Old Mar 19, 2004 | 09:34 PM
76supercab2's Avatar
76supercab2
Also, some 4x4s have a locking transfer case to prevent the power going to the AXLE with the least traction. Sort of a locking diff between the front and rear axle.
Old Mar 20, 2004 | 01:47 AM
christop43's Avatar
christop43
That is true, but when both wheels are on ice and they start spinning look out When driving on ice I prefer an open diff.
There have been a couple of times (stuck ) that I wished I didn't have the open diff.
Old Mar 20, 2004 | 03:59 AM
dinah moe's Avatar
dinah moe
Wink posi track replies
Thanks to everyone who answered so promptly. It confirms what i was trying to say (but maybe not in such a technical way). this should help the dispute!!!
Old Mar 20, 2004 | 08:34 AM
peppy's Avatar
peppy
Yea, posi Chevy. But for the generic usage......posi works fine. I rememebr when I didnt know to much about cars and trucks. Now I know just enough to get myself in trouble. It doesnt take long.
