Sponsored by: Real Truck
correct tire pressure?
Old Oct 25, 2000 | 09:16 AM
fjlee's Avatar
fjlee
I just took possession of my 2001 F250 SD.
It has long box, reg. cab, 4x4, 5 speed manual, 5.4L V8
The tires are LT235/85-R16 load range E.
Max psi listed on sidewall is 80 psi.
As delivered, it had 64 psi tire pressure.
How do I know the 64 psi is correct? How do I "close in" on the correct tire pressure?
The psi listed on the sticker on the door jamb is 50 psi front, 80 psi rear.
Lee Carkenord
Old Oct 25, 2000 | 08:31 PM
Roger_B's Avatar
Roger_B
I have 00' f250 xlt sc 4x2 5.4l 5sp 4.10ls.
I've been running 50 to 55psi front and rear.
Tire wear has been even and the ride is pretty good. Door jamb calls for 45/70. the 70 rear psi recommendation is to get max load capacity.
If your running empty, I'm sure you can get away with a psi thats as low as that which was recommended for the front..
70 psi in the rear when empty made the truck dance around quite a bit..
Old Oct 25, 2000 | 08:32 PM
jd250's Avatar
jd250
[font size="1" color="#FF0000"]LAST EDITED ON 25-Oct-00 AT 09:36 PM (EST)[/font][p]>I just took possession of my
>2001 F250 SD.
>V8
>E.
>80 psi.
>tire pressure.
>psi is correct? How
>do I "close in" on
>on the door jamb is
>rear.
> Lee Carkenord
Old Oct 25, 2000 | 08:48 PM
jd250's Avatar
jd250
You should always go by the tire pressure that is on the door jam. I have a 2000 f-250 cc w/v-10 and
the sticker has 5o psi front and 70 rear.If you put less than that in your tires they will not last that long.Same goes for if you would put to much air in them. I read where goodyear says that if you were to run your tires 4 to 5 psi low it would decrease your tire life by 15%.Plus is a little better ride worth your life????
Old Oct 25, 2000 | 10:29 PM
cjcariz's Avatar
cjcariz
Tire pressure is relevant to the load placed on them. 80 psi on the sidewall tells you how much pressure is needed for maximum load.
Old Oct 26, 2000 | 10:02 AM
agritron's Avatar
agritron
SuperDutyScaler
Aug 10, 2019 09:15 PM
jayro88
22
Aug 19, 2015 04:59 AM
Gundown64
2004 - 2008 F150
Apr 16, 2014 03:51 PM
itry2fly
Jan 10, 2013 07:29 PM
nomorecummins
6.4L Power Stroke Diesel
Sep 17, 2010 01:32 AM
