Blowing sound/ unstable idle
Old 03-18-2004, 03:03 PM
Jack DK's Avatar
Jack DK
Jack DK is offline
Question Blowing sound/ unstable idle
Have resently got a F250 year 2000 Engine: Powerstroke 7,3 diesel.
When the engine is started a blowing sound is coming from the exhaust periodically. When you starts to drive at low speed the engine is throttled also periodically and the sound is heard again.
It is very irritating
When the engine reach its normal operation temperature the problem disappeares.
I can see a linkage in the turbo outlet is moving. I believe it must be some kind of a waste gate. But why is it acting like that.
Do someone have a solution to solve this.
What is wrong? and what can be done.
Thank you in advance for any help and advice.
Best regards I.Thomsen
Old 03-18-2004, 03:07 PM
mjwhip2's Avatar
mjwhip2
mjwhip2 is offline
Sounds a lot like the ebpv. Helps your truck warm up, completely normal. Can always disconnect.
Mike
Old 03-18-2004, 03:10 PM
strangmk's Avatar
strangmk
strangmk is offline
From what I have read here, it sounds like your EBPV Exhaust Back Pressure Valve. It is supposed to close when the engine is cold to warm up the truck faster. I unplugged mine.
Old 03-18-2004, 03:11 PM
mjwhip2's Avatar
mjwhip2
mjwhip2 is offline
search this forum for ebpv. You'll get all the information you would ever want or need concerning this.
Mike
Old 03-19-2004, 01:01 AM
Jack DK's Avatar
Jack DK
Jack DK is offline
Thumbs up Disconnecting EBPV device
Thank you very much for your advice so far.
In which way is it best to disconnect this EBPV device.??
By mechanical blocking or removing the linkage, or jumping some electrical sensor. ?
I believe there must be some kind of device sencing the temperature of the engine.
Do disconnecting the EBPV not have any negative influence, except for longer warm up periode.
Of cause you must go easy with the engine until it has the prober temperature.
I wonder why Ford have made this solution for warm up.
Brgds I. Thomsen
Old 03-19-2004, 06:11 AM
Jack DK's Avatar
Jack DK
Jack DK is offline
Disconnected EBPV
I have now disconnected the plug to the sensor on the turbo charger. Now the engine behaves normal also in cold condition.
Thank you again to this great forum and the people who helped me.
Best Regards I. Thomsen
rexpedition99
1997-2006 Expedition & Navigator
20
08-24-2012 12:40 PM
virgojeep
12-11-2009 06:27 PM
The Duke
1983 - 2012 Ranger & B-Series
12-16-2008 01:06 PM
SDTruckMan
2004 - 2008 F150
05-10-2007 12:10 AM
97F350PowerStroke
01-29-2007 09:55 PM
Quick Reply: Blowing sound/ unstable idle
