Offroad & 4x4
rim size?
Old Mar 18, 2004 | 02:03 PM
fishin machine's Avatar
fishin machine
rim size?
I'm looking into putting 33 x 12.5 15r on my Bronco. Will they fit on my stock 15x8 rim. If not what size do I need.
Old Mar 18, 2004 | 02:06 PM
85351ho's Avatar
85351ho
yes they will fit fine on a 15x8, and even a 15x7.
you sure your stock rims aint 15x7?....most all ive seen are
Old Mar 18, 2004 | 11:53 PM
mrwizard's Avatar
mrwizard
They will FIT on an 8" rim, but every tire manufacturer I've ever seen says 8.5" to 10" is the recommended width for a 12.50" tire. It is possible you could have problems with warranty issues if you have tire problems and they are not on recommended size rims. Besides, they look much better on 10" rims anyway.
Old Mar 19, 2004 | 12:44 AM
SoCalDesertRider's Avatar
SoCalDesertRider
I agree, 10" is the way to go on 12.50's.
Old Mar 19, 2004 | 08:29 AM
85351ho's Avatar
85351ho
no reason in buying new wheels when they work just fine on a 15x7 or 8
Old Mar 19, 2004 | 09:41 AM
KJKozak2's Avatar
KJKozak2
I had 33x12.5s on 10" rims on my 78 until I got my 35s. My 79 had the stock steel rims that measured about 6 1/2" between the beads. I took the stock sized tires off and mounted the 33x12.5s on those rims.
They look kinda funny and do rub the radius arms at full turn with the plow up, but they hold air and handle ok. I don't think I'd take it on the highway, though.
Kevin K.
