Heater wires???
Old Mar 18, 2004 | 09:44 AM
aintskeered's Avatar
aintskeered
Question Heater wires???
I have two wires coming out the front of my grill, that have plug ends on them...is there anywhere I can look up info on these, to check them properly to see if they even work, I don't want to plug them in, and burn anything up, but if they work, then I sure could use them!!
Old Mar 19, 2004 | 04:17 PM
zamboni250's Avatar
zamboni250
I have the same thing. I was thinking that one was a block heater. But have no idea what the other one is. Could it be two block heaters?
Old Mar 19, 2004 | 07:23 PM
82F100SWB's Avatar
82F100SWB
Both are block heaters, gas engines 5.8L and bigger came with two.
To test them, check for continuity between the 2 spade terminals. All that they are is a heatng element.
if you plug them in and they work, they work, if they don't, they don't... wouldn't hurt to trace the wires and make sure they aren't worn through from rubbing anywhere.
Old Mar 23, 2004 | 03:02 PM
zamboni250's Avatar
zamboni250
Thanks 82F... Dual block heaters. BONUS!
Old Mar 23, 2004 | 03:37 PM
Beast12's Avatar
Beast12
I don't even have one you lucky boy!
-Matt
