Modular Engine Website
Old Mar 17, 2004 | 09:48 PM
Normy's Avatar
Normy
Question Modular Engine Website
Could someone please direct me to a good website with technical information [bore/stroke/bore spacing/ history] about the modular V8 engines that Ford produces? I am setting up a .com website that will deal with EngineTrivia.
Thanx in advance!
Normy!
'97 Aerostar 3.0
PS- any information on four and six cylinder Ford engines would be appreciated as well!
Old Mar 18, 2004 | 10:46 AM
grizz5675's Avatar
grizz5675
cant remember the site but i have info on the 2001 5.4 lariat supercrew 4x4 heres some /compression ratio 9.0:1/horsepower rpm 260@4500/torque350@2500/bore and stroke 3.55x4.16in - 90.2x105.7mm/ignition Edis/instalation front longitudinally mounted/fuel type grade unleaded;87 octane/oil 6 quart system motorcraft5w20/transmission 4R70W 4speed auto./gear ratios - 1st 2.84 2nd 1.55 3rd 1.00 4th 0.70 / steering suspension standard 16 in./ brakes front & rear discs. with four wheel antilock system/ ................dimensions overall length 225.9/ width 79.9 /overall height76.9/wheelbase 138.8/ front overhang 38.7/..................... interior dimensions / headroom 39.8/ shoulder room 63.7/hiproom 59.8 / max. leg room 41.0...................... rear interior/headroom 39.8 / shoulder room 63.3/ hiproom 58.0 / max. leg room 36.8.............................................c argo / box volume 44.2 / width @ wheelhousing 50.0 / box length 67.2 / box height 20.2........................ turning circle curb to curb 45.9 -- wall to wall47.7................... track width front 65.4 -- rear 65.4........................ fuel tank 25 gal. / max payload capacity 1715 - 1900 / gvwr 6750 / trailor towing 7,700 hope this helps i am pretty sure i found this in ford enthusiast web site.
Old Mar 18, 2004 | 02:43 PM
JustinH's Avatar
JustinH
www.modulardepot.com
All the smart mod motor guys are on that forum.
Old Mar 18, 2004 | 08:23 PM
LxMan1's Avatar
LxMan1
Go to the top right side of your screen and click on specs. It will tell you all you want to know. Or even easier, click here https://www.ford-trucks.com/specs/index.html
