1978 - 1996 Big Bronco
Cheapo Lift
Old Mar 17, 2004 | 05:05 PM
broncobillybob's Avatar
broncobillybob
Cheapo Lift
Hello Guys,
Here's the skinny:
I was sitting next to a 93ish F250 today in traffic and noticed that he was several inches higher than I due to the factory stance of the truck. So I thought to myself, swap over F250 coils and shocks from the front over to my Bronco to lift the front and flip my springs over for the back lift. It'd be cheap cause I can get the hookup at a junkyard and get the parts cheap and easy. But I say to myself what about your lines, would that make them not long enough? How strong are the rear springs flipped, could you actually hurt your beloved beast this way? Could the springs take a heavy load or even tow still? What about swipping the F250 rear springs and making them fit your Bronco, then I don't have to worry about loads and towing- cause they're off a F250? What do you guys think? If this can work it will go hand in hand with what we all suffer from: lack of funds syndrome.
Thanks. -William
Old Mar 17, 2004 | 07:01 PM
treehugger36's Avatar
treehugger36
ok, as we all know, I am not the brightest person. Can you explain to me how flipping your rear springs will gain you any rear height? I just cant seem to wrap my mind around it.
McNabb
Old Mar 17, 2004 | 08:42 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Flipping the leaf springs will get you lower, but flipping the shakles will get you about 4" of lift. Maybe thats what he ment.
Also, you can't swap the coils from an f-250 cause it has leaf springs all around.
Old Mar 17, 2004 | 08:48 PM
broncobillybob
What he said. Are there any factroy springs from anything that would provide lift and fit for the front? Dang, there goes my idea. Does doing that to the shackles endanger loads and stuff?
Old Mar 17, 2004 | 09:00 PM
BroncoRoadKill
To do a shakle flip, it requiers new mounts on the frame, and you need too beef up your shakles, or some companys offer the whole kits for around 200 bucks.
Old Mar 18, 2004 | 08:51 AM
AzPete's Avatar
AzPete
How far are you trying to lift it? I am going to install the Daystar spring spacers on mine to give me about 1.5 - 2 in lift in the front to clear my 33's better.
Old Mar 18, 2004 | 10:09 AM
Salmonhead's Avatar
Salmonhead
I'd forget the f250 stuff. For a cheap lift use the spacers in front (under $50) & a tuff country add a leaf in back (about 50). This will get you a nice 2". I still use my stock size KYB shocks. A lot less work to. I pull a 4000# camper and the add a leafs have held there lift real good.
Old Mar 18, 2004 | 11:01 AM
broncobillybob
Thanks guys for the suggestions we'll see what happens this summer. -William
Old Mar 18, 2004 | 11:36 AM
fishin machine's Avatar
fishin machine
Hey AzPete,
How did you space out that bumper, and do your tires rub on tight turns. i'm looing at doing the same thing.
Thanks
Abel
Old Mar 18, 2004 | 05:01 PM
AzPete's Avatar
AzPete
I removed the bumper at the bracket. I removed the old bolts and pad also. Then I purchased four bolts and six nuts (locking type) that were long (3" I think) enough to move the bumper out and still a bit of room to play with. Mounted the bolts into the bumper in place of the old bracket leaving them loose enough for adjustment to fit in the holes. Then I used a double nut system to mount it on the truck again. Now, I am able to adjust each side in and the tilt out to get the perfect look. I used the best quality bolts I could find also. Worked great. No tire rub except for the larger bumps. That will be fixed with the daystar spacers.
