1978 - 1996 Big Bronco
Knocking noise
Old Mar 17, 2004 | 05:01 PM
monkejunk's Avatar
monkejunk
Knocking noise
I had to repear a ghole in my gear box ( i think it was my gear box) After fixing it I started to drive and now it makes a kinda popping noise when i start moving. I hav eknow clue as to why it is happening. Any help would be great.
Old Mar 17, 2004 | 06:41 PM
79Smack's Avatar
79Smack
Was the hole in the transmission? T-case? Differential?
If you busted a hole in it (whatever it is) then you could have pushed the broken piece into the "box".
Don't drive it...get it to someone who can help before you do some serious damage.
Good luck.
Old Mar 17, 2004 | 06:49 PM
monkejunk's Avatar
monkejunk
There wasn't much of a hole it was more like a crack. It was on the plate in the middle of the rear axle. I drove maybe 100 feet after I found out I had got a hole. I welded it close and refilled it with gear lube.
Old Mar 17, 2004 | 07:33 PM
79Smack's Avatar
79Smack
You mean the diff cover? Take it off and check it out...maybe it got pushed in a little and now its rubbing the ring gear?
Old Mar 18, 2004 | 04:20 PM
jfrbronco's Avatar
jfrbronco
I'd take it off and inspect it all if it bent you canhammer it back or juust get a cheap chome one from jegs or summit
