1978 - 1996 Big Bronco
wiper problems
Old Mar 17, 2004 | 04:14 PM
jfrbronco's Avatar
jfrbronco
Arrow wiper problems
wipers don't work when turned on, they do work when the turn signal is used or if I hit the highbeams?
wiper motor is good but how do I check the switch?
94 bronco eb power everthing, cruise control
any help would be great,
JFR
Old Mar 17, 2004 | 08:29 PM
Swit's Avatar
Swit
I'm guessing here mind you, but I'm suspicious of that multi-function switch. I have a 94 XLT with power what-nots and a glitchy intermmitant wiper. Signals, high beams work fine, but the interval control doesn't have too much effect... until you hit the turn signal or such.
On mine the suspicion is the multi-function (the switch body in the steering column cowl that does the work of the gadgets on the turn signal lever) or *possibly* the intervalometer under the dash. But I tend to the column switch.
Hane's manual does a fair job of "How-to" it seems on the replacement.
FWIW, I've been replacing window and lock switches on mine.. almost all new (within a couple years) at this point.. How's yours?
Swit
