differential compatibility/Replacing U Joints
Old Mar 17, 2004 | 01:31 PM
moose94's Avatar
moose94
Well the 4.56 swap fell thru so looks like I'll be looking to swap in a similar rear end with whatever I can use. But the thing is which ones can I use? I've got the 1994 Flange Type differential, would one from an eariler f150 work?
The difference I believe is in the yoke, correct? There is flange type and u bolt type. Could I use one from an 1986+ f150?
Any feedback would be great. Just looking to for 3.55 ratio and I can't get into changing the ratio because my front u joints need to be done.
Oh one more question - How long does it take to replace the 3 front u joints? Either by shop or by yourself? I know you have to take the spindles, hubs and drop the diff, but how hard is it to do?
Thanks guys.
Old Mar 18, 2004 | 09:20 PM
moose94's Avatar
moose94
anyone?
Old Apr 10, 2004 | 12:05 PM
moose94's Avatar
moose94
There are a few rear ends in my local classifides and they are for 86+ year f150's. Could it be possible to swap a u-bolt for a flange type? There are alot of these rear ends in the paper and I want to know if I could use one.
Also, there is an '83 f150 9" rear end and a dana 44 posi front for sale, would that go under my truck or not? What are the differences between this and my '94 besides a speedo?
Old Apr 10, 2004 | 09:06 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Moose, I'm guessing that if you get the u-bolt style axle, as long as you get the driveshaft with it, you should be ok, or you can have your driveshaft rebuilt using the u-bolt yoke, but you will have to get a hold of the yoke if the driveshaft shop doesn't have one.
Old Apr 10, 2004 | 09:43 PM
moose94's Avatar
moose94
K so I'll start calling around. Will basically any 8.8 work? I just want the housing right? Not anything else, what years had the u-bolt and what years had the pinion style? As long as it's the correct ratio and stuff, what about the speedometer sensor is it different in '94?
Old Apr 12, 2004 | 09:29 AM
moose94's Avatar
moose94
Alright guys well she's toast. The rear end is almost gone and I need this info really fast. If anyone can tell me if other rear ends are compatible that would be great. I need some help here because I have no truck to drive!
I'm basically looking at '87+ rear ends but which year turned over to flange type?
Old Apr 12, 2004 | 02:02 PM
fordman300's Avatar
fordman300
if it has a flange style yoke just replace it with your u bolt style one. Problem solved
Old Apr 12, 2004 | 02:36 PM
moose94's Avatar
moose94
No No No guys I have a flange type. So I was wondering what years switched from u-bolt to flange cause I have a flange style yoke. Alright. Thanks tho I guess I'm going to pick up any old rear end as long as it's in good condition. Cause my truck ain't goin nowhere.
Old Apr 12, 2004 | 02:59 PM
fordman300's Avatar
fordman300
all you will have to do is swap yokes or maybe take the flange off of the end of the drive shaft and clamp the caps in the ubolt style yoke
Old Apr 12, 2004 | 03:19 PM
moose94's Avatar
moose94
sweet guys thanks alot.
