Sponsored by: Kumho
Question about backspacing
Old Mar 17, 2004 | 12:09 PM
Trek93023's Avatar
Trek93023
If I were to put LT/315/75/R16 Tires on my truck...would less backspacing mean that they are less likely to rub the frame of the truck. My wheels I think are 4.5 in backspacing
What is the difference between backspacing and the offset?
Thanks
Old Mar 17, 2004 | 02:02 PM
Ford79's Avatar
Ford79
Backspace is the distance from the wheel lip to the mounting surface.
Offset is the difference, usually in mm, the wheel mounting surface if from the center of the rim.
Yes, less backspace on the wheels will move the tire away from the frame, it will also add more stress to components like wheel bearings.
Old Mar 17, 2004 | 04:36 PM
85351ho's Avatar
85351ho
and make your tire more prone to rubbing things like your bumper, inner fender and fender
