MAP sensor
Old Mar 17, 2004 | 11:18 AM
gburkett's Avatar
gburkett
MAP sensor
Cab anyone tell about what the map sensor is for and where it's located? I'm wondering if it has anything to do with fuel milage?
Old Mar 17, 2004 | 11:32 AM
jpsartre12's Avatar
jpsartre12
A MAP sensor measures the Manifold Absolute Pressure (hence MAP) and is a means of determining an engine's load condition.
A high vacuum is a low manifold absolute pressure. The two are inversely related, so under high load, you have a low vacuum and high manifold absolute pressure. It is normally found after an engine's throttle body, just before or on the intake manifold. I don't know where it's specifically located on the 7.3L.
Old Mar 17, 2004 | 11:48 AM
JMorton's Avatar
JMorton
It is located on the passenger side of the firewall, on the heater case. There is a vacuum line on the turbo y-pipe, follow this line towards the heater case and it ends at the MAP sensor.
Old Mar 17, 2004 | 12:32 PM
gburkett's Avatar
gburkett
Thanks guys, I appreciate the reply. How much does it have to do with the fuel milage?
Old Mar 17, 2004 | 02:12 PM
jpsartre12's Avatar
jpsartre12
The short answer is "lots". MAP output is fed into the PCM which controls the fuel injectors. False readings can lead to either lean or overly rich conditions.
Old Mar 17, 2004 | 10:22 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
A couple of diesel specific points that I think are applicable to this thread.
1. There is no throttle body.
2. There is no vaccuum, only pressure.
3. Diesels always run lean.
On the PSD the MAP sensors basic function is to measure the engine load via the amount of boost being produced and send that info to the PCM so that it can adjust the fuel curve accordingly. It's possible that a "slightly bad" MAP sensor could affect the milage, but I would think there would be other, more severe symptoms associated with it. Bad idle, poor running, lack of power, check engine light....that sort of thing.
Old Mar 18, 2004 | 07:37 PM
gburkett's Avatar
gburkett
Would an air leak in the line also cause the milage to go down? meybe I'm crazy or just don't know what it's suppose to sound like but the engine sounds like it's getting air in the line to the injectors. is there a way to tell if you have an air leak in the fuel lines? I appreciate the help from everyone, makes this forum great!
Old Mar 18, 2004 | 08:17 PM
Stroker01's Avatar
Stroker01
If your getting air in the line to the injectors, you'd be able to tell cause your exaust would be white and smokey. If it sounds like an air leak just after a cold startup and goes away, that is normal.
Old Mar 18, 2004 | 08:22 PM
cookie88's Avatar
cookie88
FTE Emeritus
What year is the truck? If it's a Superduty with a stock fuel system then it is very likely that the fuel system is drawing air.
Do a search for "tank mods" and "pre-pump mod" and let us know if the descriptions found there in are similar to your situation.
How poor is the milage that spawned the thread?
Old Mar 20, 2004 | 02:48 PM
gburkett's Avatar
gburkett
Cookie, I have a 01 crew, 4x4. I have done the fuel tank mods and put the inline filter on and changed the clamps like the mod says to. When I bought the truck I was getting about 16mpg. Now I can't get better than 13.5mpg. I have the stinger w/chip and a 203 thermostat so I thought I would be getting better than this! The sounds isn't a hiss or anything.....just sounds like it's missing at low speeds. to me it sounds like it would if there was air in the line but I have no smoke out the exhaust either. I did talk to the dealer once and was told that this was normal milage but I have seen to many others to know that this isn't true. Oh, by the way, I do drive conservately (most of the time).
Old Mar 20, 2004 | 03:40 PM
cookie88's Avatar
cookie88
FTE Emeritus
Is it still cold in Idaho? Might just be winter fuel. Mine got low 15's for the last couple months, but with the return of summer fuel down south it's back to the mid 17's the last 2+ tanks.
Jnowaczyk
Modular V10 (6.8l)
Nov 5, 2013 02:55 AM
mikec91
35
Sep 22, 2012 09:32 PM
frankyford
Jul 26, 2009 08:49 PM
cowmilker08
Mar 22, 2009 11:46 PM
oldhampete
Oct 28, 2003 10:24 PM
