96 5.0L ABS Relay Code
Old Mar 17, 2004 | 11:05 AM
mhester's Avatar
mhester
My ABS light comes on and stays on at least every 3-4 times I start up. Took to mechanic and they got a faulty relay code. They checked all the relays in the big relay box up by the master cylinder, but they are all fine. They don't know where else under the hood the ABS relay could be. Any clues?
Old Mar 18, 2004 | 07:54 PM
prcrboy's Avatar
prcrboy
Exactly what was the code the pulled? You can watch the ABS light at start-up and it will flash the code and you count the number of flashes.
Old Mar 18, 2004 | 09:46 PM
mhester's Avatar
mhester
Not sure exactly, they just said it was an ABS relay malfunction code. I'll take it up to Autozone and use their code reader. So I should read the code as it starts up and count the number of times it flashes the code and that will narraow it down for me?
