89 7.3l wont start
Old Mar 20, 2004 | 08:53 AM
jetlee's Avatar
jetlee
the truck is an automatic and i dont here any clicking from the controller at all. when i tested the wires to the glow plugs they did not light the test light. do you know how much glow plugs go for and how much a controller costs?
Old Mar 20, 2004 | 05:54 PM
International Tech's Avatar
International Tech
i was askin if the solenoid at the injection pump is getting power (turning on).
Old Mar 20, 2004 | 06:56 PM
kitsapcountychopper's Avatar
kitsapcountychopper
on top of the injection pump is a big wire plug and with the switch on it should be hot.also plug in the truck for a couple hours it will help if the block heater is working
Old Mar 20, 2004 | 10:26 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Beru glow plugs are around 10 dollars each at Autozone. Please specify Beru plugs.
If you go that route the controller is around 170 dollars at Ford.
You can also put a manual switch button on the relay to heat the glowplugs for about 5 dollars.
The reason I asked if it was a manual, you could give it a pull to start it and see how it ran before spending any dollars on it.
Old Mar 21, 2004 | 09:02 AM
7.3 sled's Avatar
7.3 sled
controler cost
WheHope this helpsn I called o'reily's they told me about 95$$ for a controler!
