Shudder and U joints?
Old Mar 16, 2004 | 08:19 PM
captron904's Avatar
captron904
My 1995 F-150 automatic 131k miles is shuddering only when accelerating. It's really bad from 20mph to 40. If I take my foot off the gas it's fine. Any Ideas? Driveshaft?
Old Mar 16, 2004 | 08:52 PM
85351ho's Avatar
85351ho
does it matter if it slike floored, or regualr accelerating?
Old Mar 16, 2004 | 09:15 PM
Beast12's Avatar
Beast12
It's not your u-joints probably if it stops when you take your foot off the gas.
I would guess motor mounts or transmission crossmember bushings or mounts.
-Matt
Old Mar 17, 2004 | 11:37 AM
captron904's Avatar
captron904
Thanks! I'll check
Old Mar 17, 2004 | 11:58 AM
Beast12's Avatar
Beast12
Ok, let us know what you find. Good luck!
-Matt
Old Mar 18, 2004 | 05:48 PM
captron904's Avatar
captron904
Ended up being the u joint's. Had them replaced and now I remember what a normal ride in my rtruck feels like. What a relief.
Thanks for the input
Old Mar 18, 2004 | 05:55 PM
Beast12's Avatar
Beast12
Glad you got it worked out....I guess I was wrong! DOH! Anyways, keep those things greased. I grease them as well as my front end every time I change my oil.
-Matt
Old Mar 18, 2004 | 06:12 PM
captron904's Avatar
captron904
Thanks, The new ones have grease fittings.
Old Mar 29, 2004 | 07:15 PM
dfox55's Avatar
dfox55
Captron904's vibration fix
Captron,
I've got a similiar problem with my '94 F150 ext cab. I feel a vibration in the drivetrain between 20-50 mph. I was wondering if you could tell me exactly what you replaced (u-joints, retainer clips, needle bearings, any other bearings). Also, how long did you drive your truck with the vibration problem? I've put about 100 miles on mine since I first noticed the problem and am worried that it might have damaged other bearings seals. Any info you could give would be greatly appreciated. Thanks.
Dan Fox
Old Mar 30, 2004 | 06:49 AM
captron904's Avatar
captron904
dfox, it was noticably shuddering for about 3 months. Last year I started hearing a creaking noise similure to a tire rubbing on something each revolution. I finally trcked the noise to the drive shaft. So the u joint bearings must have been bad for about 5 months.I think on my truck the shudder was gradually getting worse because I remember even last year, "something didn't feel right". I wasn't able to do the work myself, but they changed the u-joints, retainer clips, needle bearings.
