Sponsored by: Auxito
97 F250LD diff code
Old Mar 16, 2004 | 04:17 PM
gh1051's Avatar
gh1051
97 F250LD diff code
I have a 97 f250 LD 5.4 with limited slip, the code is B6.
What is the model of this rear end and what is the ratio?
Thanks
Old Mar 16, 2004 | 04:30 PM
F2504x4's Avatar
F2504x4
hi, and welcome to FTE, i have the same truck, its 3.73. is your a 4x4?
Old Mar 16, 2004 | 04:50 PM
gh1051's Avatar
gh1051
No it's a 2 wheel, its a great truck. I used to pull a 24' 5th wheel, (1984) OK but now I have a new 25' with slide out and its more of a chore to pull. I'm thinking of installing a 4.10 gearset. What do you think?
Old Mar 16, 2004 | 05:29 PM
F2504x4's Avatar
F2504x4
it would help some, but maybe getting it to breath better,[k&n filter, exhaust] would be money better spent, maybe a chip? i like the rearend, overall. i pull a trailor 5000lbs. it does okay, i'm going for the k&n first then exhaust, just for alittle more H.P.i've been reading the forum's and that seems to be the most comman upgrades.
Old Mar 17, 2004 | 09:30 PM
kspilkinton's Avatar
kspilkinton
You have the Sterling 10.25" semi-floater.
-Kerry
Old Mar 17, 2004 | 09:50 PM
F2504x4's Avatar
F2504x4
Kerry,
how good of an axle is this? and what does 10.25 mean?
Old Mar 20, 2004 | 02:54 PM
kspilkinton
The 10.25" is the size of the ring gear in the ring and pinion set. As a general rule, as the ring gear increases in size, so does it's thickness and durability.... as far as I know the Sterling semi-floater is a desing based on the 9.75" unit found in the '97 and up F150's and Expy's. Sterling rears have been installed with the 10.25 inch ring gear size in 3/4 and 1 ton Ford trucks for more than a few years. Many of the early to mid 90's versions used a full floating design. This means the axle shafts themselves are not held in with "c" clips like a semi floater and both ends are sitting on bearings. The vehicle weight is supported through the tire/wheel and bearings, (hence full floating)... this makes it more reliable. Not like a semi-floater which uses the axle, shafts and outer bearings to support the vehicle....
-Kerry
Old Mar 20, 2004 | 03:02 PM
F2504x4's Avatar
F2504x4
Kerry,
Thank you for the info, is it diffcult to replace the front seal on this unit ? the first one was done by the dealer at 30,000 miles, its now at 119. and starting to drip.
Old Mar 20, 2004 | 04:00 PM
kspilkinton
Not too sure... haven't had to replace one myself. Once the yoke is out of the way it should be pretty easy. The yoke's the hard part.
As a note, the synthetic fluid may be the culprit. The stuff is awesome for friction and wear, but it'll find those microscopic cracks and really show itself unlike the dino stuff.
-Kerry
