automatic transmission
Old Mar 16, 2004 | 01:39 PM
windyd's Avatar
windyd
1990 f150, pickup truck, trans fluid ok, no vaccum assist, regular linkage with one electrical connection, will shift at full throttle only, goes in gear ok, reverse or forward, will not shift unless full throttle
Old Mar 16, 2004 | 03:05 PM
larry derouin's Avatar
larry derouin
Look for a cable that attaches to your throtle and then goes into the tranny. Called a TV Cable. It may be mal adjusted.
Get out your trusty(HA!) HAYNES manual and follow procedure for TV CABLE.
Old Mar 16, 2004 | 04:43 PM
windyd's Avatar
windyd
i appreciate the post will check manual for adjustment thanks
