Cam upgrade?
Old Mar 16, 2004 | 09:02 AM
nhfire 77's Avatar
nhfire 77
Cam upgrade?
ok another wild question. Can you/is there an upgrade the cam in a 98 X 5.0 without modifying the whole engine?
Old Mar 16, 2004 | 09:26 AM
CobraXP's Avatar
CobraXP
What do you mean by modifying the whole engine?
Yes, you can upgrade the cam. Most common to upgrade to is a FMS E303. Most are doing it with a 1.62 or 1.7 roller rocker combo. I've got an E303 and 1.7's in the garage now, just have to wait until I have a couple of days off to get this done.
Old Mar 16, 2004 | 10:16 AM
nhfire 77's Avatar
nhfire 77
A bit vague huh. Can you repl the cam without modifying anything else and cam you access it just by sliding it out the front of the block or do you have to go in through the upper half
Old Mar 16, 2004 | 10:28 AM
CobraXP's Avatar
CobraXP
Be ready to spend about 2 days...
If you do not remove the engine from the X, you have to remove the entire front clip - grille, radiator, fan, bumper, etc. Then break down the upper/lower intake, valve covers, timing cover, etc. It is a pretty lengthy porcess. You don't go all the way to a bare block, but you will get sort of close...
I've left out a lot of steps, but can help further if you need....
On Edit:
Guess I should have said this is to do the cam and the roller/rockers. I would not do a cam only and leave the factory roller/rockers in. Replacing the cam in an Epxlorer 302 is bascially no different than any other 302, just have less space to do it in...
