V8 Differences
Old Mar 18, 2004 | 08:11 PM
LxMan1's Avatar
LxMan1
I have even seen an 82 with a 3.8 V6. WHY!!!!!
I never understodd why Ford had to have so may variations of engine configurations!!!
The other 2 American makers had small blocks and big blocks. Not small blocks, 351W, 335 series, FE series, and 385 series. And most do not interchange much of anything. It is so confusing sometimes!!
Now they are at it again!! The 4.6 and 5.4 are different. Like a 302 and 351W. The 5.4 is taller and wider, on top of that, you have a 4.6 Windsor and a 4.6 Romeo that are also different.
Will the madness ever end???
Old Mar 18, 2004 | 10:20 PM
jimlj's Avatar
jimlj
Another thing I have heard, and I hope you guys will let me know if I am wrong, the 351c never left the factory in a truck.??
Old Mar 18, 2004 | 10:24 PM
Mil1ion's Avatar
Mil1ion
Correct No 351Clevos in Trucks.
Old Mar 18, 2004 | 10:28 PM
swann79's Avatar
swann79
yup, no Cs. Make for some awesome transplants though!
Old Mar 19, 2004 | 12:00 AM
bigperm2's Avatar
bigperm2
Actually, all the FE's are very interchangable, they all have the same deck height and journal sizes. They just dont share the trans. bolt patern with any of the other V8's. 390 block + 428 crank = 410 merc!!
If you want to call the EB a truck, they came with the 289. Does the 260 and 289 share the same stroke?
Old Mar 19, 2004 | 12:02 AM
Matts72's Avatar
Matts72
Whats an "EB"
Old Mar 19, 2004 | 12:08 AM
Thomsen's Avatar
Thomsen
I kind of like the fords being so different...any dummy can work or swap motors in a chebby...that cant be said for ford, you have to know what you're doin.
Old Mar 19, 2004 | 12:09 AM
Matts72's Avatar
Matts72
A monkey can build a chevy, it takes brains to build a ford.
You know why they have so many aftermarket parts for chevy? 'cause ford built it right the first time.
Old Mar 19, 2004 | 12:11 AM
bigperm2's Avatar
bigperm2
EB is an Early Bronco 66-77
Old Mar 19, 2004 | 09:32 PM
LxMan1's Avatar
LxMan1
I don't really have a problem with the many differences, it just makes most Ford parts more expensive because of the variations. Although, 5.0 parts are getting as easy to get as small block Chebby parts now.
Old Mar 23, 2004 | 01:37 AM
janfer's Avatar
janfer
What would be the best all round standard engine for for a 1978-1985 working truck (F250 4x4)? Some say that the 351M is not reliable enough for a hard working truck. Others say ,stick to the 300 sixes for better low-end totque and reliability.
Old Mar 23, 2004 | 07:35 AM
jimlj's Avatar
jimlj
While the 351m may not have the most power, I would never class it as un-reliable. There are way too many of them running around in cars and trucks with 200,000 plus miles to say they are not relaible. I think the 300 six is a good engine also.
If milage is not a concern, I think the 460 is the best gas motor out there. Properly tuned it will make more power and get as good or better milage than most other V-8's.
If money is no problem, there are several diesel engines that come to mind.
Old Mar 23, 2004 | 01:19 PM
  #28
BrentKasson's Avatar
BrentKasson
Almost any Ford V-8 will be excellent for a work truck, whether it be a 351M/W, 400, 429/460. I don't really know about a 302, just seems like more of a car motor. I've heard the 300 I-6 is bulletproof. All of these engines will perform well with just a little love ($500) and should be reliable.
Old Mar 24, 2004 | 07:27 AM
  #29
swann79's Avatar
swann79
That's right, any V-8 in those years will do the job just fine. The only exception, IMO, has already been stated... I like the 300 I-6 better for trucks than the 302.
