Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Beeswax on a grinding wheel
Old Mar 16, 2004 | 12:28 AM
Mike W's Avatar
Mike W
I asked a shop that sells abrasives about a grinding wheel made for aluminum. He said they are available but beeswax will work on a regular wheel. It is also good on abrasive belts and files. Also on carbide lathe tools used on alum.
Old Mar 16, 2004 | 07:38 AM
bronc95's Avatar
bronc95
I would be leery of using anything but a wheel designed for aluminum-aluminum fragments in a regular wheel create a wedging effect in the voids between abrasive particles-I have seen wheels come apart because of this-I will agree with using it on abrasive belts-it does lubricate the belt and they will last longer and cut smoother
Old Mar 16, 2004 | 09:06 AM
beartracks's Avatar
beartracks
The lubricant help to keep the alumnum from packing up in the wheel. Commonly used on sand paper rolls.
Old Mar 16, 2004 | 12:40 PM
rebocardo's Avatar
rebocardo
Get the right grinding wheel, at the very least it will make the right type cut instead of melting the aluminum off in rough chunks. I made the mistake once of using a cut off tool to trim some aluminum, the wheel did suffer.
Old Mar 16, 2004 | 03:06 PM
1BigFish's Avatar
1BigFish
Try chalk... yeah, chalk ! Great for stopping files and wheels from loading up with aluminum. Dirt cheap too!
A.M.F.
Old Mar 17, 2004 | 09:33 PM
Ggg6's Avatar
Ggg6
I have used both bees wax and chalk on files and belt sanders for working with Aluminum. As far as grinding wheels are concerned I use the correct type only. It is just too dangerous messing with something spinning that fast.
Cwsocks
Apr 18, 2017 05:55 PM
Lubbockguy1979
Ford Truck Parts for Sale
Jan 5, 2016 09:01 PM
cypressford
Nov 21, 2015 01:31 PM
nnero
2009 - 2014 F150
18
Aug 28, 2012 10:13 PM
73strokin
Mar 5, 2009 11:19 PM
