1978 - 1996 Big Bronco
Transmission
Old Mar 15, 2004 | 12:29 PM
Corbin18's Avatar
Corbin18
Transmission
I just was wondering if any one had ever changed from an automatic to a standard transmission before? Is there any problems with doing this and also what bell housings fit? My bronco has the 5.8L and a c-6. I want to put a 5 speed i found in it. Thanks for any information.
Old Mar 15, 2004 | 12:47 PM
BillyBob69's Avatar
BillyBob69
All depends on what the donor tranny is from, and what it is going into. What year is your truck?
Old Mar 15, 2004 | 02:30 PM
Corbin18's Avatar
Corbin18
Sorry I have a 1989 Bronco and the donor is I think a 1989 also but it has a 302. does anyone know if the bell housings are the same?
andy
Old Mar 15, 2004 | 02:47 PM
BillyBob69's Avatar
BillyBob69
They should be the same but the only thing I can remember that you will need to get different is the flex plate. Otherwise it should bolt up.
Old Mar 15, 2004 | 04:18 PM
DW2455's Avatar
DW2455
bellhousing are the same bolt pattern. DW
Old Mar 15, 2004 | 10:11 PM
horton-racing's Avatar
horton-racing
You may need to swap the driveshafts. You will need the trans tunnel pan and the flywheel/clutch setup from the donor. Also swap steering columns and instrument panel to make it look right, like it was made at the factory. Stuff you don`t have to do but could. Don`t know if the transfer case input shafts are the same. May need to swap them (transfer cases) too. Good luck.
